Need a TSB
Old Jan 22, 2012
04 Honda Civic's Avatar
Need a TSB
Can someone please link me to the tsb below.
"08-094 DEC 08 Lighting - Inner Tail Lamps/License Plate Lamps Inop. "
I cant find it anywhere, is there a site with all the Honda TSB's downloadable in PDF format?
Thanks
Old Jan 23, 2012
Re: Need a TSB
Google not turned on there?
http://ww2.justanswer.com/uploads/th...36_A08-094.pdf
Old Jan 23, 2012
Re: Need a TSB
**** you lol, what did you search?
Old Jan 23, 2012
Re: Need a TSB
Basically all I should do is solder/heatshrink then just cut the clips?
Edit:nm they put the clips back.
Old Jan 23, 2012
Re: Need a TSB
googled
honda 08-094
look for PDF's
Looks like they want you to get the broken splice repaired and then move it away from the areas that have to flex so it won't break again.
Old Jan 23, 2012
Re: Need a TSB
Thats what you would think..Looks like they put it in the same exact spot..
Old Jan 23, 2012
Re: Need a TSB
You expected me to actually read it? I work at a dealership, I can't read!
Someone had to read this part to me:
CORRECTIVE ACTION
Repair and relocate the splice in the rear wire harness.
Maybe to relieve stress more than get it out of the area that flexes then.
Old Jan 23, 2012
Re: Need a TSB
Damn cocky techs, glad I dont bring my car to the dealer.
Old Jan 23, 2012
Re: Need a TSB
Real world: I would have never seen the bulletin. I would have gone straight for the wiring and fixed as I see fit. Move the splice out of the flex area and add wire as necessary. (Using factory wire scrounged from old saved harnesses, in most cases. Aftermarket wire doesn't flex for very long.)
Old Jan 23, 2012
Re: Need a TSB
Nice ****ing comment there.
I LOL'd.
Old Jan 23, 2012
Re: Need a TSB
Lol, I repped you didnt I? Its all in good fun, thanks again.
Old Jan 23, 2012
Re: Need a TSB
Yes you did, thanks. I was referring to the **** in the comment attached to it. That's what I LOL'd at.
(I'm still not sure what all this rep stuff is though. Darn kids, get off my lawn!)
styles234
21
Nov 19, 2019 07:23 AM
Sep 27, 2015 11:33 AM
Roman Rembacz
Jul 16, 2015 12:30 PM
thirdhonda
Feb 9, 2004 12:03 AM
00celicagts6spd
Dec 3, 2003 10:52 AM
