Marker Light
Old Dec 27, 2011
nieuport17's Avatar
nieuport17 is an unknown quantity at this point
Marker Light
I have an interesting phenomenon and hoping the experts on this forum can guide me in the right directions.
I have a 2001 Civic Lx.
When I turn on my headlight, the left front side marker will not turn on. But, If I activate the left signal light, it blinks.
(left front side marker = left signal light).
I check the fuse diagram, and followed all the lines, and it doesn't make sense to me why the signal light would work, but when I activate the headlight, the marker would not.
Thank you.
Old Dec 27, 2011
CraigW's Avatar
Re: Marker Light
2 filaments inside 1 bulb. 1 filament = signal / 1 filament = marker.
You likely just need a bulb.
Old Dec 29, 2011
nieuport17's Avatar
Re: Marker Light
Thank you Craig, I will replace the bulb this weekend and see
Old Jan 3, 2012
nieuport17's Avatar
Re: Marker Light
Yup, changed the bulb, that was it. The one of the two filaments burned out. Never realized that there are two filaments.
Thank you
Old Jan 3, 2012
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Re: Marker Light
Well at least it is fixed..Glad to hear you were helped out..
Poopies
Apr 20, 2017 11:36 PM
werdnahall
May 17, 2015 11:37 AM
CIVICINJEN
Nov 16, 2001 11:44 AM
CIVICINJEN
Nov 16, 2001 09:42 AM
CIVICINJEN
Nov 6, 2001 01:30 PM
