engine snoring noise
Hello All---'03 Civic coupe has weird noise heard only on decelerating-Take your foot off the gas, any speed, sounds like a snoring sound. It happens when you are using engine compression to slow down.
I would have thought it an exhaust system leak but, only on decel? It is best heard from inside the car.
Engine runs well, good power, no DTC codes.
I pulled all the intake related stuff off--nothing seemed wrong. Cold starts are fine--occasionally some momentary intake wheeze on starting.
I put it up on stands and followed the exhaust while running--no holes or noise.
Thanks for any help you can give
David
David
Re: engine snoring noise
Will it make the noise when you back up?
Any recent work done? (timing belt, bodyshop, etc.)
Manual or automatic trans?
Thanks Ezone--
Standard trans, no recent significant work. I had my son try it last night and he said it makes the sound when you accel in reverse but not when decel--????
The front motor mount does have a split but the engine doesn't roll excessively.
It all started the day after my sons replaced the battery--and lost a screwdriver in the engine compartment. Later, I pulled all the intake components out so I could see well--and concluded the screwdriver was no longer present, so probably just coincidence.
Thanks in advance, DLS
Logic says it's probably not coincidence.
You just haven't found the screwdriver yet.
Figure out how to get it to make the noise while sitting still (power brake/sidestep it?)
Look for the noise while it is happening.
If a timing belt had just been done, I would think it was the small plate under the drivers side engine mount had been spun into the wrong position.
Thanks for the ideas--
I don't think there is much liklihood that the screwdriver is still lurking somewhere.
Do Vtech engines have any vacuum controlled gates/valves between intake and exhaust? (besides EGR valve--maybe something like Ford intake manifold runner control valve?)
Problem solved--Yes, sports fans, it was the screwdriver--found after putting it up on the lift--had to remove the mount to get to it. Noise was caused when the engine rocked, it pushed the screwdriver agains the body--and transmitted the engine vibration to the car body like a drumhead.
Crazy.
DLS
Crazy.
DLS
bokogabe
May 21, 2015 09:27 PM
CurryBomb
May 8, 2015 10:16 AM
smmahan
Apr 15, 2015 08:17 PM
car, civic, decel, decelerating, engine, honda, mechanical, noise, noisy, pickup, slow, snooringnoisefromengine, snore, snoring, sounds
