Idle rough/misfiring
Old Dec 15, 2011
wildcard007's Avatar
wildcard007 is an unknown quantity at this point
ok so i got all 4 cyc. misfiring along with a rough idle. Also has a rough time starting unless i give it gas and sometimes hesitates acceleration when idling about 700rpm.
so far i have replaced:
the Cat. converter
all plugs
all coils (6 months ago)
TDC Sensor
MAP Sensor
Reman the head
Timing belt (8 months ago)
Water pump (8 months ago)
New Battery
IACV cleaned
Any ideas where else to look would be helpful
Old Dec 15, 2011
fsckewe's Avatar
fsckewe is an unknown quantity at this point
Re: Idle rough/misfiring
Hi, what engine do you have?
Does it idle rough from start? If it were a D17A2 you might want to look at the EGR vavle.
Throwing the MIL and any codes? Have you done a compression check?
Old Dec 15, 2011
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Fuel delivery problem? Waiting for more info
Old Dec 15, 2011
Yeah its the D17A2 so i'll look into that.
codes are P300-304 Random misfire ....misfire cyc 1.2.3.4.
Old Dec 15, 2011
I actually also replaced the fuel pump 5 months ago however i did not check the rest of the fuel system.
it does run fairly smooth tho at speed and higher revs (like 2000+)
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
RSKtakR
25
Sep 14, 2015 07:43 PM
2.0.0.2
Sep 14, 2015 06:38 PM
MichaelLW
Sep 14, 2015 07:15 AM
SolidHollow
15
Sep 13, 2015 11:18 AM
