Low Beams gone, Not the bulbs, not the fuses
Old 12-01-2011
DerekxxCore's Avatar
DerekxxCore is an unknown quantity at this point
Hey guys-
I have an 01 Lx Coupe. Went to get gas last night, low beams worked fine. Turned the car off to get gas, pumped it, turned her back on, no low beams. I just replaced both headlight bulbs, and when I buy bulbs I always buy four for two to keep in my trunk for spares. Replaced the bulbs at the gas station, still nothing. Throw open the hood, fuses are fine. Hi beams work fine, so I drove home with the hi beams on.
Get on the forums, and find that their was a recall for the headlight switch back in 06ish (I think). I've only had the car for about 18 months so I have no idea if the guy before me did the recall.
Could it be anything besides the recall? Should I just bring it in to the stealership and let em have at it?
Again, Thanks in advance.
Old 12-01-2011
Re: Low Beams gone, Not the bulbs, not the fuses
more than likely recall. all 2001s had the problem i believe and some 2002s. i can email it to you if you want. but its free at the dealer. you get a new wire and a headlight switch.
Old 12-02-2011
That's what I figured. Bringing it down tomorrow. My turn signal relays went about two weeks ago and replaced them, I don't know if that would have anything to do with it (maybe the switch burned out the relay? I don't know).
Old 12-03-2011
CraigW's Avatar
2 separate circuits using a common switch.
There is an issue with the low beam wiring that gets grounded when low beams are on. The connector terminal pin over heats.
stryder12
06-30-2015 08:33 PM
ericaagarcia
06-11-2015 11:29 AM
terry_tr6
HIDs and Retrofitting
05-16-2015 08:37 AM
Hondasport01
Lighting
07-12-2005 07:45 AM
EsineN
01-19-2002 09:09 AM
Quick Reply: Low Beams gone, Not the bulbs, not the fuses
