grinding noise when turning the steering wheel?
Old Nov 10, 2011
rickywf's Avatar
rickywf is an unknown quantity at this point
http://www.youtube.com/user/MultiRic.../0/-Lgo7_MiwuU
their is a video of the sound i get.
i have not done any mods to the car everything is stock.
the sound comes and goes. any ideas of what might be causing this?
thanks.
-ricky
Old Nov 10, 2011
pwnsauce's Avatar
pwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the rough
Re: grinding noise when turning the steering wheel?
check power steering fluid
Old Nov 10, 2011
rickywf's Avatar
i dont have power steering
Old Nov 10, 2011
lazlong's Avatar
Where the PS lines capped right and was there fluid left in the rack? If not, you probably need a new rack due to buildup of debris. And be sure to fill it with fluid then cap the lines securely.
EDIT: Sorry. By fluid I mean PS fluid. It also acts a lubricant.
Old Nov 10, 2011
lazlong's Avatar
I would also inspect the ball-joint, tie-rod end and the bushings
Old Nov 10, 2011
04 Honda Civic's Avatar
Ill second what lazlong said.
It could be so many things you really need to get under there and check it.
By the sound of it once you jack it up and do that movement it should be obvious.
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
anddrrey
May 11, 2015 02:30 PM
jakeconnor
May 5, 2015 07:30 AM
edgenet
May 2, 2015 08:00 PM
