Trans-axle mystery hose
Old Nov 7, 2011
Arceneaux's Avatar
Arceneaux is an unknown quantity at this point
I recently purchased my first civic and have been putting new parts in her.
I have a 2001 Civic LX with 96,000 miles.
1.7L Manual Transmission
Work I'm doing:
Timing Belt
Tune-up
New struts/springs
Problem:
After I pulled off the intake housing I noticed something odd. I'm hoping someone can tell me what this is? It is located on top of the transmission housing.(passenger side of the flywheel/clutch)
If this is the transmission dipstick...then I'll feel like an idiot.
If it is a vacuum line, where does it go? And how bad is it that it hasn't been connected.
Thanks for the help,
Markus
Old Nov 7, 2011
MelJ's Avatar
Trance Addict
Re: Trans-axle mystery hose
Our manual trannys don't have dipsticks, so you can rule that one out. It could possibly be the breather tube. Can you remove it? If so and you see a gold spout, that's what it goes to. This is based off of a past experience, so I could be completely wrong about it.
Old Nov 7, 2011
anibis's Avatar
anibis will become famous soon enoughanibis will become famous soon enough
I have an '05 and it has a hose in the same position although it's different. Mine comes up a bit and then has a 90 degree bend, it's not connected to anything.
I think it's just a breather valve, they just changed the design in later 7th gens.
Old Nov 8, 2011
Arceneaux's Avatar
You both are correct. It is a breather tube. I've ordered the elbow that goes on it, although I'm not sure it is entirely necessary. $4 at the dealer.
Thanks for the help!
Old Nov 8, 2011
beastyben1's Avatar
beastyben1 is an unknown quantity at this point
Thanks for the info! I saw that part on my 01 EX and was wondering about it.
cferry7
Oct 3, 2015 04:33 PM
Hutch1051
Sep 29, 2015 09:20 AM
Sep 27, 2015 11:33 AM
thaler4cuse
Sep 7, 2015 08:25 PM
beantech
Sep 6, 2015 01:46 AM
