Sticky gas pedal
Old Oct 30, 2011
stresscase's Avatar
stresscase is an unknown quantity at this point
Sticky gas pedal
I have a 04 civic non-V-tec. What is the probable cause of this? Thank you for your help.
Old Oct 30, 2011
Re: Sticky gas pedal
either the mechanism behind the gas pedal needs lube, or the throttle cable is getting stuck in the engine compartment due to grime and dirt on it. get some silicone and spray behind the gas pedal on the moving parts (be sure to wrap a towel around the pedal so the spray does not get on it, or it will be very slippery). then spray the exposed part of the cable near the throttle body. it could also be grime inside the throttle body causing the throttle plate to stick.
SidCivic
Sep 12, 2015 05:28 PM
mikebj23
Jul 28, 2015 08:08 PM
wootah88
Jul 21, 2015 10:22 AM
Trennytrent
Jul 10, 2015 09:01 PM
ezone
HIDs and Retrofitting
Jul 4, 2015 12:44 PM
