Electric door locks
Old Aug 27, 2011
ITSMEBOAT's Avatar
ITSMEBOAT is an unknown quantity at this point
Electric door locks
2005 honda civic LX...front drivers side works with lock switch but the other 3 do not. Took door apart today and pulled actuator. When I got it out and plugged wires back in the green piece will only go one way
when you push lock or unlock. Is it the actuator?? Thanks.
Old Aug 28, 2011
CraigW's Avatar
Re: Electric door locks
When you press the unlock the 2nd time or lock/unlock are you getting any noise from the inop doors ?
Old Aug 28, 2011
ITSMEBOAT's Avatar
Put old actuator back in as new one did not change the fact that only drivers door is controlled by electric lock button. The other 3 doors did not respond to the new or old actuator.
Old Aug 29, 2011
CraigW's Avatar
The circuit is a little strange due to the need for polarity reversal but... the 3 other locks are all on the same basic circuit, common to all 3. (drivers has it's own circuit)
Could be an open connection or an issue with the multiplex.
Jul 12, 2015 11:54 AM
jferristx
Jul 8, 2015 10:09 PM
Spanky4269
Jul 5, 2015 09:40 PM
h4ldol
Jun 3, 2015 03:26 PM
MamaBear2015
May 18, 2015 07:37 PM
