04 Civic Brake Pedal Noise
Old Aug 12, 2011
crothb's Avatar
crothb is an unknown quantity at this point
Good day all,
I have a 2004 Civic with 76000 miles and drives like a charm. Only draw back here is that I get a squeaking/squealing noise each time I lift my foot off the brake pedal.
Searched the existing threads and did not see anything close to my issue.
Thanks in advance.
Old Aug 12, 2011
CraigW's Avatar
Re: 04 Civic Brake Pedal Noise
Try pulling and release the hand brake a couple of time and see if the noise is still present.
The shoes rub against the backing plate and make the noise. Very common.
Old Aug 12, 2011
crothb's Avatar
Craig, thx much. I will give that a try.
Old Aug 12, 2011
could also try the 'reverse-and-brake' technique a few times. sometimes the self adjuster gets stuck and that helps free it up. find an empty lot and drive in reverse 10-15mph, then hit the brakes moderately. repeat a few times and see what happens.
Old Aug 14, 2011
crothb's Avatar
no luck with the e-brake method. used it for the last two days and sound still there. will give the reverse and brake method a try now. i am open to any suggestions to solve this.
thx again!
Old Aug 14, 2011
CraigW's Avatar
thx again!
I meant to use it as a diagnostic method, not a cure. With the car off and parked, slightly pull and release the p brake a few times and see it the chirp/squeek occurs when releasing the brake.
Old Aug 14, 2011
crothb's Avatar
Understood. If the sound remains, does that mean its time to go see the mechanic?
Old Aug 14, 2011
CraigW's Avatar
If the noise occurs during test... it is likely a pretty easy fix. And not a safety issue. It happened on my 05.
https://www.civicforums.com/forums/3...se+rear+brakes
If the shop is honest they should not charge that much to solve this, and they can do an inspection while at it.
Old Aug 14, 2011
crothb's Avatar
Craig, thanks a bunch for your help. Sound is still there, but at least now I have a better handle on understanding it and resolving it.
Old Aug 14, 2011
CraigW's Avatar
No problem, Take the info found here with you and it will cut out diagnostic time.
It really is a simple fix, assuming the drums will come off.
Old Aug 14, 2011
is this just a 1 second quick mouse squeak type of noise? i used to have that before too. everytime i would lower the ebrake (or the regular brake) it would squeak. if you hold the ebrake button and move it up and down repeatedly from top to bottom, does it keep squeaking? if so you just have to lube the ebrake cable in the drums. i kinda liked the noise tho lol
Old Aug 14, 2011
BlueEM2's Avatar
Whachya lookin at?
Mine does the same. lubricate the rear barkes and the noise will go away.. Damn Steve it drives me crazy but I haven't had time to remove the drums.
Old Aug 14, 2011
CraigW's Avatar
It is easy if the drums will come off. Mine came off by hand and the shoes can stay in place you only need to lube the points where the ] portion of the shoes contact the backing plate.
Just a tiny bit of wheel grease at each one, noise gone.
Old Aug 14, 2011
arent there a few bolt holes you can thread a bolt into for popping the drum off?
Old Aug 14, 2011
CraigW's Avatar
M6 or M8, I bought both just in case. I think M8.
Old Aug 18, 2011
BlueEM2's Avatar
Whachya lookin at?
M8 bolts are the right ones, spray some white lithium grease where the E brake cable enters the drum assembly as well ... Try to shoot it as far up the cable as possible. Make sure you don't accidentally pop the cylinder out or one of the springs or you will be in a world of hurt, especially if you've never changed drum brakes before.. mwahahaha
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ghondavic
Transmission
Apr 12, 2017 09:37 PM
bsmiley
Apr 27, 2015 01:27 PM
TaiChi
Canada West
Nov 8, 2001 01:21 AM
CiViCPrAnInG2k1
Nov 1, 2001 03:47 PM
