Another Overheating Thread!
Old Jul 6, 2011
specialized7's Avatar
specialized7 is an unknown quantity at this point
Well guys Long story short.
On a roadtrip the Cooling fan decided to blow up and put a hole in the radiator. ok so we patched the radiator and made it home. I just recently put a new fan in and it worked good no over heating when idling. I thought everything was fixed.
Today im driving a buddy home when i notice the temp jut about at H so i pull over and let it cool. I have noticed that the Fan isnt kicking in anymore. i checked the fuse its all good but i dont know how to test relays?
or what else could be the problem?
what is this fan switch people talk about?
any insight would be appreciated.
thanks!
Old Jul 7, 2011
MelJ's Avatar
Trance Addict
Re: Another Overheating Thread!
[YOUTUBE]http://www.youtube.com/watch?v=3JB63ebFfgU[/YOUTUBE]
Old Jul 7, 2011
can i swap a relay to test it? i dont have a multimeter or whatever there called
Old Jul 8, 2011
green01civic's Avatar
green01civic will become famous soon enoughgreen01civic will become famous soon enough
Sure!
Honk your horn a few times, does it work?
Now swap the cooling fan relay with the horn relay.
Honk the horn again a few times, does it still work? (If yes, they're probably both good, if the horn no longer works, it's definitely a bad relay... I'd keep it in the horn socket until you get the new part).
If that isn't the culprit, it is possible the Radiator Fan Switch is broken (it's mounted in the thermostat housing). Also ensure no wires were damaged when the fan blew up.
Old Jul 11, 2011
Thanks i tested it all out and it seems like its working now? im not sure if maybe a bad connection in there or what .
I replaced the fuse aswell but it didnt look blown to me
alinaray
18
Aug 24, 2015 01:04 PM
USCGBM
Aug 12, 2015 04:22 PM
Dangerousjordan
Jul 30, 2015 11:19 AM
liagreenhalgh92
Jul 21, 2015 01:31 PM
EliseKStewart
Jul 15, 2015 11:11 AM
