EVAP Leak?
Old Jun 27, 2011
robe5000's Avatar
robe5000 is an unknown quantity at this point
EVAP Leak?
-heres the situation,
a month ago changed my plugs and air filter, (i used a small amount of anti-seize around the threads and some electric tune-up grease on the contact tips of the plugs - FYI) a day later my engine light came on, i let it go for a while and tried resetting the ECU but it came back on after a day or two
-so today i went to the honda dealer to have my timing belt changed , i asked to have the codes checked and he wanted 70$ just to check them, i laughed and said no thank you, but the tech checked the codes anyway and on my bill he stated that the code was an "EVAP code" and will return in a few days due to "EVAP leak"
any info or help on this would be much appreciated
Old Jul 3, 2011
lewi103's Avatar
lewi103 is an unknown quantity at this point
Re: EVAP Leak?
check your fuel cap seal,lines,gas tank and neck and canaster for leaks goodluck.
Civic15
18
Sep 19, 2017 07:48 PM
mjdiaz89
Jun 21, 2016 09:26 PM
CBRBlaize
Jun 17, 2016 06:11 PM
MrOldskool
Aug 18, 2015 09:58 AM
mistermenphis22
Jul 13, 2015 04:43 PM
