A/C not working
Old Jun 2, 2011
civicbaby's Avatar
civicbaby is an unknown quantity at this point
Question A/C not working
My AC isnt working...I turn it on and it blows warm air the fan works but my compressor doesnt kick in to start the AC ....the compressor is working ...I took it to honda and they said I need to replace the PCM ...... should i replace the PCM or should i have Aamco trace my electrical wires to see whats goin on or is that a waste of time
Old Jun 3, 2011
lazlong's Avatar
Re: A/C not working
I would definitely get a second opinion. Honda is going to charge you near $2000 and it may not fix it. I've never heard of the ECM/PCM going bad make the A/C not work. I would start by jumping the A/C switch and/or relay.
Old Jun 4, 2011
civicbaby's Avatar
Re: A/C not working
if i jump start the A/C its works so there is something else going on just a pain in the u kno what to figure it out
Old Jun 4, 2011
lazlong's Avatar
Re: A/C not working
Download the manual: https://www.civicforums.com/forums/1...e-updated.html There is a diagnostic for the A/C system and step-by-step diagnosis. Sorry, I should have told ya this first but, I was at the end of a long day.
Old Jun 12, 2011
civicbaby's Avatar
Re: A/C not working
So I am done trying to figure out what the problem is with my A/C a mechanic said he could put a toggle switch in and i could use it to operate my A/C instead of the regular A/C button ..... he says it perfectly ok and nothing will burn out in my car because it will go through the A/C relay its just a different switch to turn it on and off......is there anyone else on here who has ever had this done before
mikemc422
Aug 9, 2018 05:41 PM
trellex
May 24, 2015 04:39 PM
ORskier
May 3, 2015 12:54 PM
paulnguyen
Apr 20, 2015 01:33 PM
Pir8pete
165
Mar 6, 2009 05:16 PM
