Catalitic Converter
Old May 11, 2011
12219front's Avatar
12219front is an unknown quantity at this point
Catalitic Converter
Is there any way to bypass or eliminate my NOX 3way catalitic converter on my 2005 Honda Civic Hybrid? The check engine light is on and the new part is around $1000.
Thanks,
Ed
Old May 11, 2011
Re: Catalitic Converter
you can take the cat off and gut the inside mesh so its a plain old hollow pipe, then put it back together and use the spark plug nonfouler trick to space back the oxygen sensor to turn the engine light off. bear in mind this is illegal and in many states can cost a huge fine (more than replacing the converter with a new one). it will also cause the car to pollute more and fail a smog check if they use the exhaust sniffer. it may be a hybrid but it still uses a regular 1.3L engine.
Old May 11, 2011
MindBomber's Avatar
Live for the Twisties
There are a few tricks that can't eliminate the CEL, but like gearbox said, if they analyze the exhaust emissions you'll never pass without a functioning cat. If you want to save money some of the non-oem cats will work well.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Luluharp
Sep 27, 2015 11:56 AM
pilebuck13
Sep 21, 2015 10:45 PM
Dsmak
Sep 10, 2015 08:30 PM
