High temp gauge.
High temp gauge.
Our '03' civic appears to be overheating according to the temp gauge, it fluctuates from hot to cold. The motor itself does not seem hot and there's lots of coolant. The heater even blows cool air when this occurs.
Would it be a thermostat, sensor ??? Any suggestions?
Re: High temp gauge.
You have air in the coolant system. Start by bleeding the air out. If that does not work replace your thermostat and rad cap. If that does not work get a shop to do a pressure test to check for leaks. If they can't find any leaks its probably your head gasket or water pump
it's psychosomatic, this is a 9th gen 2012 civic forum, as informed in the description of the forum "In 2012 Honda released it's 9th Generation Civic. (Its not out yet!- Don't post in here!)" - they are not out yet, so you actually do not have the car, you are dreaming.
yours is a 7th gen, so please post there.
Hmm, this does seem to be happening more and more often
... Unfortunatly my mod powers do not extend this far so I can't move it. I do however hope you can get your overheating issues resolved!
... Unfortunatly my mod powers do not extend this far so I can't move it. I do however hope you can get your overheating issues resolved! Thread
mjdiaz89
Jun 21, 2016 09:26 PM
FutureCivicOwnr
Aug 11, 2015 10:59 PM
Martinez8o5
Jul 31, 2015 10:58 PM
