Manual Driver Side Lock has Ceased Working
Old Apr 15, 2011
SamWalker06's Avatar
SamWalker06
SamWalker06 is an unknown quantity at this point
Two days ago my driver side (manual) lock stopped working on my Honda 2005 Civic. Previously, there had been absolutely nothing wrong, then I put my key in and I have to force it in, but then it won't turn. It feels as if there's something in the way, so maybe a piece of plastic is stuck or broken. The key works in all the other locks, so I know it's not a problem with the key.
Does anyone know of any solutions/tutorials to change the lock? I've found several that are for powered locks, and I'm assuming a manual lock is easier to change, but I'd still like a walk-through so as not to botch it.
Old Apr 15, 2011
Re: Manual Driver Side Lock has Ceased Working
you need to change out the latch assembly in the door. same happened to me and a new one fixed it. its about the same work to change manual and power. remove door panel, remove a few screws and lockrods, take the old out and bolt the new in. you just need #2 in the pic. #6 is the power actuator that bolts to it.
Old Apr 15, 2011
SamWalker06
Fantastic! Thanks!
Old Dec 30, 2011
7thgendx's Avatar
7thgendx is an unknown quantity at this point
I know old thread, but any updates or anyone else expierence this?
My keys seems to get stuck before ever fully getting into the lock. If I jiggle it and get it in enough it won't unlock. So I try multiple times before it goes in smoothly and it unlocks/locks just fine. Does this sound like it may be an issue with #27 instead of #2?
Would I need a new key for this?
Old Jan 7, 2012
7thgendx's Avatar
update:
Don't need a reply.
Went ahead and bought the lock and replaced it. Fixed the problem great.
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Fastfebur
Apr 22, 2015 01:37 PM
ej8
Apr 13, 2015 06:36 PM
mwwhonda
Nov 7, 2001 07:24 PM
EXWisdom
Nov 5, 2001 10:24 PM
