door lock
Old Feb 25, 2011
leosar's Avatar
leosar is an unknown quantity at this point
door lock
hi
i have honda civic 2004 and ,i will tell you what happens
i opened the passenger door to take something from my car and leaved it
open , after around half minute i heard the locks for all doors cliking and closing, i repeated the action and got same thing
i would ask if this is normal ?
please somebody tell me,is it normal or i have electric problem?
thanks
Old Feb 26, 2011
Re: door lock
My 02 does that. I thought it was normal. It doesn't if the car is running (and perhaps if the key is just in the ignition, but I don't wanna test that.)
Old Feb 26, 2011
CraigW's Avatar
Re: door lock
Check the passenger side rubber covered plunger switch... It acts like it does not know you opened the passenger door.
An easy test would be to check the dome light's operation when passenger door is opened.
Old Feb 26, 2011
Kennykid2002's Avatar
Kenny the Ricer
Re: door lock
Yep, relay or something's messed up, not picking up that you've opened the door
Normal is if you unlocked car without opening doors, auto relock in 30 seconds
If you open any door within the 30 second time frame, door will not relock
Old Feb 26, 2011
Re: door lock
I missed the part where you left the door open. ^^what they said
Old Feb 26, 2011
leosar's Avatar
Re: door lock
hi
i would thank you ,because my problem is solved
i checked the passenger side switch and the dome lights operation
i remoeved the switch (it was loose) fixed it,the problem solved
thanks again
Aladinbama
Aug 23, 2015 06:37 AM
viperGTS
Jul 27, 2015 08:40 PM
ayoitzjulesdx98
Jul 26, 2015 02:25 PM
ballmich
Jul 9, 2015 11:59 AM
Spanky4269
Jul 5, 2015 09:40 PM
