Head gasket
Old Jan 4, 2011
streetneons's Avatar
streetneons is an unknown quantity at this point
Head gasket
I have 2004 civic ex. I am having a problem with coolant rising and being pushed threw my overflow tank. I have done a lot of looking online and pretty much all signs are leading to a failed head gasket, but the problem is we did that coolant exhaust test where the fluid will turn a different color if exhaust gases are present in the coolant, and it showed that the coolant is fine. So I have replaced the rad cap and the t.stat. and I am still having the same problem. I just wish I knew for sure that the head gasket is bad before I do all that work, If anyone has any ideas please share.
Old Jan 5, 2011
TRIZ's Avatar
Re: Head gasket
Is there coolant in the oil or vise versa??
Old Jan 5, 2011
Re: Head gasket
Nope everything looks good. One thing I am noticing is that the inside car temp gauge shows the vehicle getting up to temp where it should be, but the cooling fans only come on when the a/c is put on. If I turn it off and sit at an idle in the parking lot and rev the engine the cooling fans just will not come on. Is that normal.
cukaracha
30
Jul 26, 2015 12:01 PM
Ccoop87
Jul 9, 2015 03:26 PM
robbie374
Jul 7, 2015 02:56 AM
jdawgzcivic
Jun 30, 2015 06:35 PM
HondaHomer
May 14, 2015 12:24 PM
