Timing Belt timing problem
Old Dec 23, 2010
keewee89's Avatar
keewee89 is an unknown quantity at this point
Ok I was one of the idiots who didn't set TDC prior to belt removal. Reddawnman said to use a straightened coat hanger to even out the pistons, which I did and it left my crank pulley at the 5 o'clock position.
Do I then put the crank back at TDC? Which means the pistons won't be even anymore.
After putting the belt back on, how hard should it be to rotate the camshaft counter clockwise 2 times. I'm having to force it a lot. And the damn thing gets stuck sometimes before I can finish 2 revolutions. WTH am I doing wrong.
Old Dec 23, 2010
keewee89's Avatar
Re: Timing Belt timing problem
ignore this thread, already fixed it.
But if you'd like to help out with this new problem I got, be my quest
So after putting everything back together and having the timing right and the car finally starting. After 20 seconds or so the car starts to smoke right where at the Valve cover seal and it smokes at the heat guard of the head. Smells like something is burning, like wood is burning almost, light odor. I have new oil in it.
Any ideas?
sharp66
31
Jun 12, 2022 08:45 AM
CarStuff
Dec 6, 2020 12:52 PM
mattdoc
Mar 14, 2017 12:10 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
