passenger power window is slipping
Old Nov 13, 2010
whenever i roll down the front passenger side window from any position, the glass free-falls quickly about an inch before rolling down normally. does this sound like the regulator starting to go? maybe too much play in the wires? other than that it rolls fine like normal. just that first second feels like the window is detatched from the mechanism or something and falls before being pulled down.
Old Nov 13, 2010
Re: passenger power window is slipping
You try pulling the door panel off and physically watching what goes on?
Old Nov 14, 2010
CraigW's Avatar
You might try applying white grease to the outside face of the metal track the plastic slide rides up/down in. Also apply it to the exposed cable anywhere possible. And make sure your top & bottom window tracks are clean.
Old Nov 14, 2010
yeah it is hard to tell, it looks the same as watching it with the panel on. the regulator that bolts to the window glass is secure, i think its just slop in the cable assembly.so im just preparing for more $$ to throw away for a new one when it breaks. and my tire has a small nail hole in it too, 3rd tire this year. thats what happens with cheap junk tires i guess. i pulled it out and it didnt leak overnight so i might be okay leaving it alone. i need new tires so bad.
the window stuff is all clean, i lube it every few months both the inside and outside tracks. window rolls up/down very fast like new. just skips for a second when rolling down.
Old Nov 14, 2010
Paul79UF's Avatar
Paul79UF is an unknown quantity at this point
I'm not sure specifically about the Civic, but I've replaced the power window motors and regulators on other cars multiple times.
That sounds like one or more of the regulator's cables isn't tight due to the plastic pieces they run over/around/under being ground down or broken off over time.
You might want to just pull off the panel, and the plastic sheet behind it to see what's happening.
They have decent generic window motor/regulator assemblies on eBay. They cost about $40-50 for our GM car.
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
timpan
May 18, 2015 07:06 AM
werdnahall
May 17, 2015 11:37 AM
got2kids
May 9, 2015 06:45 PM
