sick civic
Old Nov 3, 2010
Davo's Avatar
Davo is an unknown quantity at this point
sick civic
Good day all , I have a 01 civic non vtech changed the alternator and battery the car ran o.k. for about a 1/2 hour now it runs like the timming is off it will not rev past 3500 rpm and the new spark plugs are black, so new timming belt thinking it may have jumped but no .also the green key light is on all the time as well the srs light . and no codes with the code reader.thanks Davo.
Old Nov 3, 2010
Prodresurgence's Avatar
Prodresurgence will become famous soon enough
Re: sick civic
yikes, that sounds like a lot of unrelated issues. Spark plugs are black with oil prob because the seals on the valve cover for the spark plugs are cracked or worn. Timing belts don't just jump notches unless they were improperly installed.
Old Nov 3, 2010
Davo's Avatar
Re: sick civic
plug tubes are dry. I think it,s running to rich the exhaust stinks when running. When i changed the timming belt the tensioner was lose.
Old Nov 4, 2010
Re: sick civic
So you didn't replace the tensioner...?
Old Nov 4, 2010
Davo's Avatar
Re: sick civic
yes I did,a guy at work told me that low oil pressure it will lower the rev limit but his engine is a 01 v-tech.
Old Nov 4, 2010
Re: sick civic
Low oil pressure can create low revs or dangerously high revs. If you replaced the tensioner and timing belt properly there is no way it would jump a tooth. If it did somehow jump a tooth from a poor install or something like that the valves would collide and bend each other rendering the motor useless so I don't think the timing belt is your issue. If the car is running rich you should replace both O2 sensors in your exhaust pipe, that would be my best guess as to what your problem is.
gabrown2
Apr 11, 2015 08:22 PM
blueracer
Nov 11, 2001 09:54 PM
Slickwillie
Nov 9, 2001 10:19 AM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
