Timing belt...time limit?
Old Nov 2, 2010
Berto's Avatar
Berto is an unknown quantity at this point
So I was on here reading up on the timing belt DIYs and it doesn't look like fun on this car (or any car for that matter).
I am faced with a decision. The car (2004 civic) only has 55,000 miles (GF bought it a few months ago). With that being said the timing belt is 6 years old but has not reached the mileage limit (I think is 90,000 miles?).
Should I worry about changing the timing belt this winter or should I let it ride? I am a bit spooked since the reason she got this car was because the timing belt broke on her Stratus, but it had never been done @ 190k miles
Old Nov 2, 2010
Kennykid2002's Avatar
Kenny the Ricer
Re: Timing belt...time limit?
Check the wear on the belt, if it looks solid, drive it till 90k
I'm on 60k and it looks fine
If it looks like its cracked/wearing, then you should change it
Or just change it for peace of mind
Old Nov 3, 2010
BlueEM2's Avatar
Whachya lookin at?
Best to check the belt. Unfortunately conditions make a big difference. I'm in Canada and I pulled my belt with 80k miles on it this summer(my car is a 2005). The belt looked brand new with not much wear at all on it. I changed it because I was mid head gasket replacement anyway. That being said, you may have 60k miles and your belt could be chewed... Check it.. might wanna do a valve adjustment while your there... if you have any kind of ticking at all from the engine.
Old Nov 3, 2010
yamahar6's Avatar
yamahar6 is an unknown quantity at this point
i have a 91 camry and i wanted run it till it falls apart so i will have a reason to get rid of it. until now (150k miles) has the original belt. now thats pushing the luck. surprisingly unbelievable.
beneditti
Jan 15, 2016 12:31 PM
carid
Apr 30, 2015 07:00 AM
Fastfebur
Apr 26, 2015 11:57 PM
supercivic01
South
Nov 30, 2001 11:27 AM
