shifting isn't smooth anymore...
Old Oct 20, 2010
dustysaw's Avatar
dustysaw is an unknown quantity at this point
I don't know if it's a problem or what but since i got back from my vacation, shifiting between gears hasnt been smooth, thers a bit of a clunk into every gear, i'm wondering what the problem is...wouldnt be the clutch would it?
Old Oct 20, 2010
02civicsi02's Avatar
Low and slow!
Re: shifting isn't smooth anymore...
I highly doubt it is your clutch. The only way it would be your clutch is if your throw out bearing is bad and not stopping the clutch/flywheel.
What you need to do is change the transmission fluid with honda mtf. this should help it out.
Old Oct 21, 2010
MelJ's Avatar
Trance Addict
I was gonna say mounts, but it could be the fluid from sitting for a while? My car made a clunk when I shifted but it turned out to be a bad mount in that case.
Old Oct 21, 2010
dustysaw's Avatar
Yeah the tranny fluid is pretty new, got it replaced like a year ago, and for manual transmissions its like once every 5 years or something. Could be just the cold weather maybe? I guess we'll see. For now its fine I guess.
Old Jan 8, 2011
ashokudu's Avatar
ashokudu is an unknown quantity at this point
Same thing with my car. Mine is a manual and the shifts are always a little rough in winter, once it warms up it feels a lot better.
Old Jan 9, 2011
TRIZ's Avatar
Try lubing the ball shifter under the center console.
Old Jan 9, 2011
Stock 99's Avatar
shifter bushings
Old Jan 9, 2011
TRIZ's Avatar
Its really hard for shifter bushings to go bad... people just upgrade them to aluminum to give a tighter feeling, but it really doesnt improve feel very much.
Old Jan 17, 2011
AriAnaheimGold's Avatar
AriAnaheimGold is an unknown quantity at this point
/Thread
Old Jan 23, 2011
Protan988's Avatar
Protan988 is an unknown quantity at this point
My car also shifts horrible in winter. Once spring comes around it gets better.
Old Jan 23, 2011
MelJ's Avatar
Trance Addict
Transmission fluid takes a while to warm up. When was the last time you changed it? Even here in NY at this time of year, I haven't really noticed any rough shifting though. Then again, I shift a little earlier when first driving, so that might be why
Old Jan 23, 2011
use a full synthetic like amsoil, it works better when very cold. the regular stuff needs to warm up before you will get smooth shifts.
Old Jan 24, 2011
Biscuit's Avatar
2001 Civic LX Sedan
Biscuit will become famous soon enoughBiscuit will become famous soon enough
When was the last time you checked the fluid level?
alaga
25
Aug 13, 2015 04:42 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
Jul 12, 2015 11:54 AM
trellex
Electrical
Jul 9, 2015 12:01 PM
fvckbg
Jul 7, 2015 07:08 PM
