door stuck
Old Oct 18, 2010
chase2910's Avatar
chase2910 is an unknown quantity at this point
Exclamation door stuck
hi, i have a 2005 honda civic 4 door, and the rear driver side door is jammed, it wont unlock with the remote i have ried forcing it to unlock with my hand but did not work, i have told it could be the actuator that was jammed and was quoted $65 for the part and $228 for labour, so i was wondering if i could do it myself
any ideas would be appreciated
Old Oct 18, 2010
Steven21's Avatar
Steven21 is an unknown quantity at this point
Re: door stuck
if its not the actuator then it wont cost that much could just be corrosion on your wires to that door from water. You could take the door panel off and see what you find it might be something easy as its just jammed on something
Old Oct 18, 2010
Mad Dog Tannen's Avatar
Re: door stuck
I say take the panel off and take a look it could be something very simple. It's worth a look.
Old Oct 18, 2010
CraigW's Avatar
Re: door stuck
I would certainly inspect it 1st before ordering anything... but !
You will have a hard time getting the panel off if you cannot open it.
Old Oct 18, 2010
Kennykid2002's Avatar
Kenny the Ricer
Re: door stuck
You can try taking off the handle screws, take out the plastic handle, and try to pull the rod behind it, see if that opens it
Aladinbama
Aug 23, 2015 06:37 AM
glockma630
Aug 1, 2015 10:30 AM
ayoitzjulesdx98
Jul 26, 2015 02:25 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
ballmich
Jul 9, 2015 11:59 AM
