map sensor connector broke...
Old Sep 15, 2010
assassin9874's Avatar
assassin9874 is an unknown quantity at this point
Thumbs down map sensor connector broke...
One of the wires to my map sensor connector broke off right at the connector and there is no way to repair it... I've tried looking in junk yards and everything but the only way to obtain a new connector with a pigtail is to buy a new engire wiring harness or stealing one lol.. and ideas on how i could obtain one? thanks guys
Old Sep 15, 2010
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Re: map sensor connector broke...
Depin the connector. Find a scrap connector in the junk yard. Depin that to get the pins. Or just disassemble and reuse the old pin. Attach new pin to broken wire. Repin connector.
Old Sep 15, 2010
I've tried to find replacement pins but nobody carries anything close to what the old ones look like...
Old Sep 15, 2010
lazlong's Avatar
If you can find a connector you can crack it open with a razor knife or a dremel tool for the pins.
http://www.car-part.com/ or http://www.picknpull.com/
Most Hondas and Acuras share the same connectors. For example I found a connector for my 2001 civic in a 1992 accord. If you live near one Pick-and-Pull is great for this as they don't mind if you cut the harness and they'll only charge you like $2. Good luck.
Aaizu
Jun 28, 2015 08:42 PM
paul.collins92
Jun 25, 2015 12:12 AM
tmc66
Jun 9, 2015 04:07 PM
wh3nw0rdsesc4pe
Mar 23, 2003 09:57 AM
wh3nw0rdsesc4pe
Mar 1, 2002 10:10 AM
