O2 Sensor CEL Eliminator ?
Old Aug 17, 2010
nick060200's Avatar
nick060200 is an unknown quantity at this point
does this thing work if you have a test pipe where your cat is? additionally i need to replace my upstream 02 because i have 110000 miles on the car now. should i put a new downstream o2 in with the cel eliminator or can i use the old one with the CEL eliminator? thanks guys
Old Aug 17, 2010
02civicsi02's Avatar
Low and slow!
Re: O2 Sensor CEL Eliminator ?
The eliminator does work. If the secondary o2 sensor is bad then the eliminator will not work really cause a code will be thrown cause of it bad. If it is bad then replace it and then use the eliminator.
The o2 sensor code eliminator works just like the oem cat basically. In the cat where the o2 sensor is it is around a wall where only alittle bit of air can reach it where it can read the right emissions. When you take the wall away with a race header or hi flow cat then the wall is gone and all the exhaust air is heating it and it throws the code. The eliminator replicates the cat to where alittle bit of air can reach it where it can read the right emissions.
Old Aug 17, 2010
nick060200's Avatar
thanks for the quick reply
Old Aug 17, 2010
Low and slow!
No problem.
CBRBlaize
Jun 17, 2016 06:11 PM
jzhartman
22
Jul 23, 2015 10:42 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
Kyles24
Jul 16, 2015 10:14 PM
Kyles24
Jul 12, 2015 09:15 PM
