Sport w/ Type-S 2.0 Engine??
Old Jul 28, 2010
ibizara's Avatar
ibizara is an unknown quantity at this point
Hi, my partner bought a 2004 Civic Sport (EP2) Euro Spec and we think that it has had the engine changed.. The tech specs say top speed for a 1.6 Sport is 116 MPH but with one passenger we were able to do 130 MPH. Is there a possibility that it's just been tuned or would it be more like it's been replaced with a Type-S 2.0i VTEC?
We can't tell if it's a 1.6 or not from power because the clutch has almost gone so whenever we try and floor it in a low gear the car just revs
Cheers
Old Jul 28, 2010
02civicsi02's Avatar
Low and slow!
Re: Sport w/ Type-S 2.0 Engine??
They could of swapped in the better motor from the EP3. The Ep3 is the type r version of the EP2 which you probably kno that. Um is the motor backwards meaning the exhaust manifold facing toward the back of the car and the intake manifold facing the front.
Old Jul 29, 2010
ibizara's Avatar
Well I looked at the car manual and the layout of the engine bay is set out like the Type-R and not like a Sport.... I think once the clutch is fixed and I should be able to tell if it's a 1.6 or a 2.0
Old Jul 29, 2010
check the code printed in the engine
Old Jul 29, 2010
If you can't find the tranny stamp, there is an obvious visual difference between a SOHC and a DOHC engine..
Old Jul 29, 2010
Low and slow!
If it is the ep3 type r motor then the engine code will be right below the throttle body. Its really hard to see actually, grab a flash light and look under there cause it is dark under there. It should be bout 5 inches below the throttle body somewhere.
