100-300 idol!?
Old Jul 28, 2010
bluestreak14's Avatar
bluestreak14 is an unknown quantity at this point
100-300 idol!?
i have recently done an engine swap on my car with just another stock d17a2 and i have noticed that this new engine is idling at 100-300 rpm. i have cleaned out the TB and IAC, new sparkplugs, brandnew fuelpump and i have tried to do an idol learn 2 times now. does anyone have a clue why its idling that low and could it cause any damage to my engine if its left like this.
Thanks for you help.
Old Jul 28, 2010
lazlong's Avatar
Re: 100-300 idol!?
-check for DTCs
-ignition timing
-spark plugs
-air cleaner
-PCV system
Start the engine. Run it at 3000rpm without load until the radiator fan comes on, then let it idle. Disconnect the IAC connector. Did engine speed increase or fluctuate?
Old Jul 28, 2010
Re: 100-300 idol!?
Originally Posted by lazlong
-check for DTCs
-ignition timing
-spark plugs
-air cleaner
-PCV system
you want me to disconnect the iac while its running?? what will this do?
Old Jul 28, 2010
lazlong's Avatar
Re: 100-300 idol!?
Just walking ya thru the procedure. I'm reading the service manual.
When you disconnect the IAC (while it's running) and the engine speed doesn't change you have a bad IAC.
Old Jul 28, 2010
02civicsi02's Avatar
Low and slow!
Re: 100-300 idol!?
How well did the rotor look in the IACV. The iacv rotor might be bad meaning you might need another one. Could also maybe the TBS or vacuum leak somewhere.
Old Jul 28, 2010
lazlong's Avatar
Re: 100-300 idol!?
From the service manual: When you disconnect the IAC (while it's running) and the engine speed doesn't change you have a bad IAC.
The valve may look good but be bad. Check the right way.
Yes, it could be the TBS or a vacuum leak but, check the IAC first.
Old Jul 30, 2010
Re: 100-300 idol!?
k ill check in the morning before i leave on my 14 hour roadtrip lol. hopefully its not that, but even if it is i wont be idling very much on the 401(canada) so it'll be fine. ill post my results when i get to a computer. thanks for your help.
diverdwn
Jul 6, 2014 03:33 PM
hoonigan21
Oct 5, 2011 12:09 AM
bluestreak14
Sep 17, 2010 08:46 PM
Got Boost?
May 3, 2007 01:23 PM
