Car bogs out in first 5 mins of driving
Old Jun 23, 2010
chad85's Avatar
chad85 is an unknown quantity at this point
I have a 2001 Honda civic and I've had the same problem for a couple years now. First when i start my car it starts bogging out in the first 5 minutes of driving, it usually doesn't cut out but it runs rough and sputters. I noticed that this usally occurs doing the warmer weather rather then the cold weather. It's also lacking power. I had it at a garage yesterday and they spent a couple hours trying to figure out the problem but couldn't.....now i have a couple hundred dollar bill but my car isn't fixed. Can you help me please?
Old Jun 23, 2010
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
Re: Car bogs out in first 5 mins of driving
My car did the same thing when I removed the Idle control valve when I switched to the D16y8 manifold. But it did it more so in the cold and not as bad in the warmer weather.
when it bogs down can you smell a strong fuel smell from the exhaust?
Old Jun 23, 2010
Deryk's Avatar
Deryk is an unknown quantity at this point
My civic is doing the same thing as Chad's. when it bogs at idle there is a strong smell of fuel in the exhaust. i cleaned my throttle body best i could and cleaned the idle control valve as well with no improvement. could there still be something wrong with the IAC or would it be something else?
Old Jun 23, 2010
CrewChief's Avatar
Check your plugs. See what they look like. It could be as simple is fouling plugs until they get hot.......it happens.
But sounds more like a IACV, TPS, or MAP sensor problem. If you have a buddy or someone with the same car you could try swaping the sensors and see if it fixes the problem. I'm sure someone on here lives near you.
Old Jun 23, 2010
Deryk's Avatar
i'd love to check the plugs but im having issues getting them out and i fear for the threads. i would think theyre ok as the car passed an emissions test with flying colors last august (issue was happening then too).
is there any way to check the functionality of the sensors on the throttle body?
Old Jul 30, 2010
TopDog's Avatar
TopDog is an unknown quantity at this point
Had this same problem - was the oxygen sensor.
The oxygen sensor relies on exhaust heat to operate properly - for the first few minutes of operation it has a heater - the heater crapped out so the sensor didn't work right.
Changed it out and the problem was fixed.
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
chrisod12
Apr 26, 2015 01:30 PM
McD
Apr 16, 2015 10:46 AM
smmahan
Apr 15, 2015 08:17 PM
