o2 sensor b.s.
Old Jun 30, 2010
04civic420's Avatar
04civic420 is an unknown quantity at this point
Unhappy o2 sensor b.s.
My 04's reading the codes p0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1), p0135 O2 Sensor Heater Circuit Malfunction (bank 1 sensor 1), and p0141 Sensor Heater Circuit Malfunction (bank 1 sensor 2), which sensors do i need to change out? i found the one on the cat, but i dont know if thats the only one or not.
Old Jun 30, 2010
Re: o2 sensor b.s.
Sounds like you need to change both pre- and post-cat sensors. If you look upstream of the cat, you should find the other sensor.
what trim level do you have? lx, dx, ex?
Old Jun 30, 2010
04civic420's Avatar
Re: o2 sensor b.s.
Its an ex, is it behind the heat shield on the headers?
Old Jun 30, 2010
Re: o2 sensor b.s.
Your pre-cat sensor is located close to the 90° bend (on the after part, I believe) on the downpipe. Easy to reach by jacking up the car.
Old Jun 30, 2010
04civic420's Avatar
Re: o2 sensor b.s.
i see this one, but where is the other one?
Old Jun 30, 2010
04civic420's Avatar
Re: o2 sensor b.s.
i just looked up prices too, the upstream o2 sensors 250 bucks, WTF. You think there might be other ways around it, like a loose wire or maybe clean it up or something?
Old Jun 30, 2010
Re: o2 sensor b.s.
they switched over to wideband sensors in the 04-05.. Those run a (lot) bit more expensive..
You could try cleaning it to see if it works. If it doesn't, you're just gonna have to drop the mad bank for the sensor
Oh, and your pic, I'm assuming you're looking down into the engine bay. That would be your pre-cat o2 sensor. Jack up the car and actually locate you cat, and you'll find the post-cat O2 sensor.
and BTW, you only have 1 header.. exhaust manifold, really..
Old Jul 1, 2010
04civic420's Avatar
Re: o2 sensor b.s.
yeah i know i don't know why i said it plural. lol this sucks i can't pass emissions and i don't have 300 bucks to drop on this.
Old Jul 1, 2010
Re: o2 sensor b.s.
its just a little pet peeve that developed after being on these forums for 7 years.
try a junkyard or pick-n-pull? Grab a bunch of 02 sensors from 04-05 civics. I'm sure you're bound to get a pair of functional ones
Old Jul 1, 2010
04civic420's Avatar
Re: o2 sensor b.s.
good idea, the hard part is finding 04-05 civics in the junkyards around here. i'll just call around places.
Old Feb 7, 2018
Edwin Romero's Avatar
Edwin Romero is an unknown quantity at this point
Talking Re: o2 sensor b.s.
Ok this is how it works. If you have a honda civic EX model 2004-2005 for your 02 sensors which couls be code p0134 p0135 and p0141 oxygen s3nsor heater curcuit malfuntion. Bank 1 senaor 1 and bank 1 sensor 2. Ok alot of people dont know which sensor is the right one. Thr upstream will be Air Fuel Sensor and your downstream will be your your original 02 sensor. This is for engine D17A2. I just installed them both , very easy job if you have 02 socket 3/8 drive.
BootyDo
Jun 21, 2016 03:45 PM
Green02civic
Jul 27, 2015 10:48 PM
Dani1993
Jul 24, 2015 09:02 AM
mistermenphis22
Jul 13, 2015 04:43 PM
