Removing center console on '03 Civic EX!?
Old Jun 14, 2010
tjg312's Avatar
tjg312 is an unknown quantity at this point
I'm talking about the part with the armrest that goes up and you can put things in.. not the part you put the head unit in.
Anyways I dropped some stuff down there, and I also wanna do an ebrake adjustment while i'm at it, but I just can't get the dumb thing off... I removed the 2 clips in the very front by the front cup holder, the 2 screws in the middle before the liftable armrest, and the 4 screws by the rear cup holder, but when I pull up it won't come out, I've been at it for like 45min but the dumb thing won't come out, am I missing something that I don't get?
it feels like its being held down by something in the back by the rear cup holder, but I don't see any screws or clips aside from the 4 ones on the side..
Old Jun 14, 2010
Prodresurgence's Avatar
Prodresurgence will become famous soon enough
Re: Removing center console on '03 Civic EX!?
https://www.civicforums.com/forums/7...djustment.html
Old Jun 14, 2010
this should help too https://www.civicforums.com/forums/7...gress-kit.html
Old Jun 14, 2010
tjg312's Avatar
that 1st DIY was what I initially used to try and get it off, and did everything in there and it wouldn't lift up where the rear cup holder is, I looked over the other one and it still has the same instructions pretty much, the design on mines a bit different since it has the storage spot under the armrest, and I feel like i'm missing something really obvious
Old Jun 14, 2010
is there a set of screws in the bottom of the storage thing? I am not familiar with that setup.
Old Jun 14, 2010
grendel's Avatar
grendel has a spectacular aura aboutgrendel has a spectacular aura about
Under your e-brake handle (on the top of the console), is there a small-ish tab to pry up? I've seen it before where there is a small area there with a screw underneath the tab.
Otherwise, there definitely should be a screw inside the armrest storage area, on the bottom. Maybe covered up with a small tab, so that it's not immediately visible?
Old Jun 15, 2010
tjg312's Avatar
lol thank you so much guys! i feel like a complete idiot, turned out i had to lift up the plastic carpet thing and there was a screw under there that I had to unscrew.
CarStuff
Dec 6, 2020 12:52 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
ScottyEj8_DB7
Apr 26, 2015 04:07 PM
TheRubixHorse
Apr 17, 2015 08:55 AM
GH04si
Apr 15, 2015 08:13 PM
