Run w/out Thermostat
Old Jun 5, 2010
cauz1's Avatar
cauz1 is an unknown quantity at this point
I have a 2005 EX with D17A2 engine. Is it possible to remove the thermostat and use the stock rubber gasket to seal the housing? The thermostat rim fits in the inner part of the gasket to give it strength. I'm afraid that the gasket might get dislodged cause a major leak.
Old Jun 5, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: Run w/out Thermostat
What? no.
Old Jun 5, 2010
HLC's Avatar
HLC
HLC is an unknown quantity at this point
so, you don't want coolant circulating at all?
Old Jun 5, 2010
Gold Ghost's Avatar
Gold Ghost has a spectacular aura aboutGold Ghost has a spectacular aura about
um y on earth would u do such a thing?
Old Jun 5, 2010
i think he means not use a thermostat, but the hose and stuff will still be connected, not plugged. hes wondering if the gasket by itself will still let all the parts fit together. if you live in hot climate, its prolly fine. the car will just take longer to get up to operating temp since you are circulating all the available coolant from the start. in cold weather, its a bad idea. car will take forever and possibly never warm up, also the thermo cant close if the engine temp is not hot enough, and you will get really bad gas mileage.
Old Jun 6, 2010
BlueEM2's Avatar
Whachya lookin at?
In general it's just not a good idea, I'm not sure if it's been done or not though.
g4384063
May 30, 2015 11:21 AM
beveragemp
May 25, 2015 07:11 PM
Allecr3
May 22, 2015 01:24 PM
bo_red
May 4, 2015 01:47 PM
hokiedad4
May 3, 2015 10:06 PM
