Automatic Gas Door will not work
I am new to the website and have alrady come a long way as far as knowledge. I work in a maintenance department at a paper mill but never got into car maintenance b/c I never had the time. I was always tryin to work extra hrs so I make some money...That would in turn spend all on a mechanic to fix my car...Makes sense.
Now that overtime at work has come to a halt and the Honda dealer has recommended ~$1000 in work that needs done I am taking a go at car maintenance.
Now to the problem:
The automatic gas lid on my car stopped working about 2 yrs ago. The trunk still pops open but the gas tank will not. I have been reaching my hand into the back of the trunk to open my gas tank since it broke. I refuse to pay $240 to fix this. Now that I have discovered this forum(Thank you god) I thought it might be a good idea to get this fixed.
Questions:
If anyone has had this problem, how can I tell what is wrong. The cable? The lid flange? Something else?
How can I fix it? lol
Where is the best place to get parts for this kind of stuff? Junkyards? Online? Dealer?
Thanks in advance.
-Jason
Now to the problem:
Questions:
Thanks in advance.
-Jason
Re: Automatic Gas Door will not work
Is it an 01-05 ??
Have you seen the fuel door fix website (fix kit is only for 01-05)
The cables rust & break at a certain point near the release handle.
Simply do not attempt to fix it. Just use a plastic card, (ie. credit, key chain cards issued by grocery stores etc.) No tools required. I have been doing this for 2 years on our 02 civic.
winneconnedon
winneconnedon
^ Why not fix it for 20 dollars instead of using a card? That makes no sense, The advice "Don't fix it" is the worst advice you can give... If you take care of stuff when it happens your car won't look and run like **** five years down the road.
I have the same issue, thank you for the link. First time it broke I had no gas and was sitting at the pump. Took me about three minutes to come up with the idea to pull the carpet down and try to reach the latch from the trunk.
MamaBear2015
May 3, 2015 02:17 PM
ORskier
May 3, 2015 12:54 PM
