tapping noise in engine
Old May 5, 2010
papadave's Avatar
papadave is an unknown quantity at this point
I have a 2003 Civic that has just developed a tapping sound when the engine is cold. It goes away after about a couple minutes. It is r.p.m. sensitive. The car recently turned over 100k. Two different mechanics have checked it out. Both say the noise doesn't last long enough for them to say what is causing it. All diagnostic tests show no problem. Has anyone else ever heard of or experienced this?
Old May 5, 2010
Re: tapping noise in engine
usually at 100k you should be getting the valves adjusted. they can tap as they get loose over time.
Old May 5, 2010
BlueEM2's Avatar
Whachya lookin at?
Is it a tapping noise, or a ticking noise?
Old May 6, 2010
mc670's Avatar
mc670 is an unknown quantity at this point
My car has a sort of tapping noise too, took it to the dealer yesteday for a valve adjustment.. this cleared up alot of the ticking but my manifold also has a crack in it, which is still making a lil' bit of a racket. Check your manifold and get your valves adjusted, that should help.
bokogabe
May 21, 2015 09:27 PM
crowtoo
May 11, 2015 06:50 PM
CurryBomb
May 8, 2015 10:16 AM
silvervtec01
Dec 9, 2001 08:50 PM
TAZZ
Dec 5, 2001 09:35 PM
