Loose wiper blades - need help tightening them
Old Jan 11, 2010
bymitten's Avatar
bymitten is an unknown quantity at this point
Unhappy Loose wiper blades - need help tightening them
Hey everyone,
I've noticed my wiper blades don't have much tension or force against the windshield anymore and hence, their performance isn't great. I found the following link on Youtube, yet my wipers don't have a "hinge pin and joint mechanism". If they do, it's hiding under a plastic piece or something. I can post a pic if it's needed.
http://www.youtube.com/watch?v=PtURvZKwmsg
I was wondering how I can put more "spring" into the arm so when I lift the blades up and then lower them, they "snap" down onto the windshield.
Thanks in advance for the help.
Old Jan 11, 2010
Re: Loose wiper blades - need help tightening them
you may need better wipers. the best ive tried were bosch micro edge, but those newer beam style icons work good too. the spring in the arm might also be tired and due for replacement.
Old Jan 12, 2010
bymitten's Avatar
Can the spring itself be swapped out or is a new arm needed?
Old Jan 12, 2010
bymitten's Avatar
The wiper blades themselves are Michelin Reflexs and are only a month or so used. So they're pretty brand new.
Old Jan 12, 2010
what kind of car? usually the whole arm needs to be replaced which is fairly easy. just pop off the cap, undo the nut, and swap them out. arm runs anywhere from $15-30 and may even be available at auto parts stores (special order).
Old Jan 12, 2010
bymitten's Avatar
Well, a Honda Civic of course. :P 2001, 4 door. Thanks for the advice. I appreciate it.
h4ldol
Apr 24, 2017 08:16 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
Joecrowe
Sep 24, 2015 09:12 AM
MichaelLW
Sep 14, 2015 07:15 AM
Dsmak
Sep 10, 2015 08:30 PM
