Floor Heat Only Works on Passenger Side?
Old Dec 22, 2009
CLH2991's Avatar
CLH2991 is an unknown quantity at this point
The problem is simple, but I'm not really sure where to look to try and fix it.
When I turn on the floor heat, I get air from both sides. However, the driver's side is cold, but the passenger's side is warm. All the other vents work properly.
Any ideas on where to look/how to get at it?
Old Dec 22, 2009
Re: Floor Heat Only Works on Passenger Side?
hmm, prolly an air mix control problem. unfortunately, you may need to remove the dash or at least parts of it to see whats going on. take out the lower console first, and see if you can feel the vents as it moves backwards, so feel where the heat stops.
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
crowtoo
May 11, 2015 06:50 PM
fordfocussucks
Nov 19, 2001 07:22 PM
mwwhonda
Nov 7, 2001 07:24 PM
