Flushed the radiator, and now something's wrong..
Old Dec 22, 2009
izotop's Avatar
izotop is an unknown quantity at this point
Hi guys,
today I decided to make it a car maintenance day, and obviously everything didn't go well.
So I flushed my power steering fluid by emptying and filling the reservoir a couple of times, which pretty much did the job.
Also, I've decided to flush the radiator by simply replacing the old fluid that was in with OEM honda fluid. I opened the valve in the bottom, let it drain, and filled it again.
It squeezed the hoses a couple times to get most of the air off of them and added some more coolant in the mean time.
I think there, my mistake was that I turned on the car until it heated up, but did not turn the heater on. I went for a little ride and my car doesn't seem to overheat.
When I rev up the engine from idle, I hear kind of a bubble sound coming from the engine bay. It really sounds like there is air the hoses or somewhere in the system. When I'm looking at the engine bay, I hear no bubbles...but when I'm IN the car, I hear it...
So I jacked the nose of the car up, turned the car and the heater on full blast, waited for the fan to come on many many times, and added fluid when it dropped a bit. But then, even though no more fluid can get it, I still hear the bubble sound when I rev it up from idle. I did that last procedure 2-3 times: went for a ride, jacked the nose, waited for the fan to come on, added a little bit of fluid (even if there is just a really small quantity that goes in), and on and on...
I don't want to screw up components of the cooling system nor my engine!
Is that normal to hear these bubbles after the flush has been done?
If not, what else should I do to get rid of the air?
I think I put about a gallon in the reservoir, so there should not be missing too much fluid...
Thanks for your help!
Old Dec 22, 2009
04 Honda Civic's Avatar
Re: Flushed the radiator, and now something's wrong..
Its not that big of a deal as long as your not overheating. Does your heat work ok, it could just be tiny air pockets in your heater core. They will go away over time, as long as everything works I wouldnt worry. Usually whenever you refill coolant this happens.
Old Dec 22, 2009
izotop's Avatar
The heater works perfectly and the engine temperature needle stays a little bit below the half mark on the temp gauge, as usual. Nothing seems abnormal apart from this bubble sound.
I guess I'll wait a couple of days and see what happens.
Thanks for your reply.
Old Dec 22, 2009
i did the same thing, i had to bleed the air 5 times and the last two times the front was up higher parked on an incline. i got as much air out as possible with heat on full and engine warmed up, but i still had some air noises inside. after about a week of driving, i dont hear it anymore. its important to get most of the air out, and over time the rest will leave on its own. so long as you got alot of air out, i dont think you will overheat. if after a week you still hear it, then you need to bleed again. its a pain, but at least the new coolant lasts 5 yrs.
Old Dec 22, 2009
izotop's Avatar
Yeah, happily we don't need to do that over again every year :| What a pain!
Oh I have another question, should the fan inside the car be all the way on when I bleed the system?
solarpunk70
Apr 12, 2016 11:43 AM
cferry7
Oct 3, 2015 04:33 PM
anubis62
Sep 27, 2015 12:56 AM
260000milesgoal
Sep 25, 2015 07:41 PM
tooly145
Sep 5, 2015 01:05 AM
