Fuel pump not working
Old Nov 16, 2009
walshie's Avatar
walshie is an unknown quantity at this point
I have a 2001 Honda Civic 1.7L coupe. The fuel pump stopped making the normal buzzing sound when I first turn the ignition. Since then, I've replaced the fuel pump and PGM-FI main relay No. 2 (The blue one behind the glove box). In addition, I also checked the 15a fuse for the fuel pump located in the fuse box under the steering wheel. Its still not working and I'm totally lost on what I can check next.
Any advice or suggestions much appreciated.
Steve
Old Nov 16, 2009
Re: Fuel pump not working
could be a problem with the immobilizer security system. does the green key light flash on the gauges when you try to start it?
Old Nov 16, 2009
CraigW's Avatar
What does the green light in the dash shaped like a key do when ignition is turned on to position II ?? (immobilizer system light) it should come on solid for about 3 seconds and then go off.
If you put your fingers on the blue relay you replaced can you feel or hear a click from it when key 1st turned to position II ??
Old Nov 16, 2009
walshie's Avatar
The green key light comes on for approx 3 seconds then proceeds to just blink.
When I put my finger on the relay, I believe I can feel a slight click when the key is turned to position II.
Old Nov 17, 2009
CraigW's Avatar
Well... The flashing key icon is indicating a immobilizer issue.
This is a quote: "If the wrong key has been used or the code was not recieved or recognized by the unit, the indicator will come on for about 2 seconds, then blink until the ignition switch is turned off."
Old Nov 17, 2009
walshie's Avatar
Thanks. I've been using the same set of keys since I bought the car. Any suggestions on what I can do to fix this problem? Or is it time to call a tow company and have my local Honda Mechanic look into?
Old Nov 17, 2009
CraigW's Avatar
You may contact the dealer and explain what happened and also contact some locksmiths ( the keyshop near me has a outside banner sign about transponder keys) Someone may be able to explain what can and cannot be done by whom.
Old Nov 17, 2009
try a different key if you have a spare. otherwise key will prolly need to be replaced and reprogrammed, or immobilizer may need replacing.
Old Nov 20, 2009
djaemac's Avatar
djaemac is an unknown quantity at this point
Steve
im having the EXACT same issue.
i had a blown fuel pump fuse at first, so i changed it and i heard the humming noise again. Car started right up and i turned it off and tried to restart it again, but it wouldn't. No more humming noise again and this time i think i fried the fuel pump relay. What the hell is causing this.
Old Nov 24, 2009
walshie's Avatar
I finally broke down and had my car towed to my local dealership to diagnose the issue and it seems the ECM has to be replaced. They want $1000+ cdn for the ECM and installation!!!!
What blows my mind is I had this same unit replaced in 2004, so this would be the 3rd ECM for this car.
With that said, anyone out there have an ECM for sale - (Part #: 37820-PLM-C03).
djaemac
When my car originally started acting up, it was doing the same thing. One minute it would work (fuel pump would kick in) and then the car would cut out. Would give it an hour or so and try again. The car would start then cut out. Finally, it just didn't work at all. I however didn't have a blown fuse for the fuel pump like you did.
Old Nov 24, 2009
check your alternator ground if you keep blowing ecus. and you should be able to find one for $100 on ebay usually or junkyard.
Old Nov 26, 2009
walshie's Avatar
I found one at a local scrap yard for $150 cdn. Hoping this will finally solve the issue.
I will also run by the service dept your suggestion regarding the alternator ground.
Thanks again!!
Old Nov 27, 2009
walshie's Avatar
The part I ordered (37820-PLM-C03) did not get done in time and I missed out. After speaking with my dealer, they told me any of the following part numbers will be ok (37820-PLM-C03, 37820-PLM-C01 or 37820-PLM-C02). I've lost any bit of faith I've had in my local dealership and just wanted to confirm with anyone on this site that they are correct that any of the above part numbers will work.
Thanks again!
CarStuff
Dec 6, 2020 12:52 PM
Jonnie.
Jan 13, 2019 11:21 AM
mrcell24
May 19, 2015 10:02 AM
