Squealing from fan
Old Oct 2, 2009
Demarini's Avatar
Demarini is an unknown quantity at this point
Squealing from fan
I own a 2005 Civic Si with about 87,000 km's on it and after a while, I hear a squealing noise. When I turn the fan off, the squealing stops, turn the fan on and it starts up again. What would be causing this?
Old Oct 2, 2009
CraigW's Avatar
Re: Squealing from fan
Could be a noisy bushing or bearing in the blower motor, you may be able to lube it to quiet.
Debris has gotten into area and is making noise when fan on.
Old Oct 2, 2009
are you sure its the fan? or are you turning the a/c on and just guessing its the fan making noise when it could be the a/c belt.
Old Oct 5, 2009
Demarini's Avatar
It was definitely not the a/c belt. I had the heat on. It was about 6 degrees celcius so the a/c was not required.
Old Oct 5, 2009
oh wait is this noise happening inside the car? if so then its prolly the blower motor as already mentioned.
solarpunk70
Apr 12, 2016 11:43 AM
Bonobo
Oct 2, 2015 06:58 PM
Junquito89
Sep 27, 2015 10:22 PM
anubis62
Sep 27, 2015 12:56 AM
hondalx2002
18
Sep 15, 2015 10:54 PM
