Weird issue with turn signals
Old Sep 20, 2009
hmbre97's Avatar
hmbre97 is an unknown quantity at this point
This is on a 04 EX coupe. I've been having intermittent issues with my turn signals and the fuse blowing in the interior fuse box for about a week now.
I don't think it's a physical short because as soon as the turn signal fuse pops, you can turn on the hazards and they work fine and all bulbs will blink. Also, the fise popping is totally random. I put a fuse in and it popped as soon as I turned on the right blinker. I then immediately replaced the fuse and tured on the right blinker again and it worked fine for 15 minutes. At this point, it sounds like the turn signal switch itself having issues. I just wanted to see if anyone else had any ideas.
Old Sep 20, 2009
Re: Weird issue with turn signals
the hazards use a separate circuit from the turn signal switch. it seems like a switch issue, or possibly a problem in the bulb socket where the wires are crossing over depending if the car bumps them a certain way maybe.
Old Sep 21, 2009
CraigW's Avatar
^^^ how are they separate ?? (if you unplug the hazard switch the turn signals won't work)
Exactly what fuse is blowing when this happens ??
Any recent electrical work or options added to the car or wiring changes ??
Old Sep 21, 2009
i think it uses a different flasher circuit or something. i may be wrong, i thought i remember something like that from the electrical manual. it so that if something happens to the turn signal switch, the hazards still function normally.
Poopies
Apr 20, 2017 11:36 PM
steveneddy
May 19, 2015 02:39 PM
shaejb15
Apr 26, 2015 07:44 PM
Fastfebur
Apr 22, 2015 01:37 PM
wawacito
May 14, 2002 07:33 PM
