oil filler cap
Old Sep 20, 2009
lionel84's Avatar
lionel84 is an unknown quantity at this point
oil filler cap
hi all , i ran into a big issue now need you guys advise what could be the problem . I have white smoke coming out of my oil filler cap as well as my oil catch tank !!! , could it be worn piston ring or valve issue . My engine has being rebuilt and clock only 10000km only...
Old Sep 20, 2009
Re: oil filler cap
white smoke usually means coolant is burning, which usually means blown headgasket.
Old Sep 20, 2009
greeen01civic4d's Avatar
Re: oil filler cap
and why r u running a catch can?
Old Sep 20, 2009
Re: oil filler cap
turbo? idk, the pcv system is already very efficient
Old Sep 20, 2009
lionel84's Avatar
Re: oil filler cap
am running NA , compression is about 13 , stage 2 cam ,valve spring upgraded and fully ported head . Had broken the tensioner pulley twice , but did not hurt any of the engine component. Head gasket has being change lately . Water temp and oil temp all running around 80+ degree . I Still suspect the oil ring or valve seals. By the way any one manage to customize the tesioner pulley to make it dead rather then able to move.
Old Sep 20, 2009
Re: oil filler cap
compression seems very high and could explain why the head gasket is blowing.
Old Sep 20, 2009
lionel84's Avatar
Re: oil filler cap
maybe i will just strip the head and check on the gasket again ... gearbox do you think the rings are worn.
liagreenhalgh92
Jul 21, 2015 01:31 PM
EliseKStewart
Jul 15, 2015 11:11 AM
Hqly2001
22
Jul 12, 2015 06:44 PM
CivicsClass101
Jul 9, 2015 11:14 AM
Bounddyy
Jul 8, 2015 11:22 AM
