Trying to replace right CV axle (Please help)
Old Sep 16, 2009
BenDover's Avatar
BenDover is an unknown quantity at this point
Sorry for the multiple posts, I also posted this in the DIY section.
Here is my scenario...
Car: 2001 Honda Civic EX coupe with a manual transmission and with ABS.
Job: Replace worn right/passenger CV axle.
I bought a new CV at Napa and began disassembling the right front wheel to remove the damaged axle. I took off the hub assembly, removed the hub assembly from the axle and moved to taking the inner side of the axle apart from the transmission. This is where I am stuck. Everywhere that I have read, it says to just pry the axle from the transmission housing, but I think that the axle is held in by a ring clip on the inner axle stub (inside the tranny). Am I wrong?
I've tried prying it, and it seems to be requiring a lot more force than I would suspect, so I quit that and came inside the house and got on the computer to make sure that I do this correctly.
Can you please help me out?
hans.pcguy
May 16, 2015 09:54 PM
R3KogHyZe
May 13, 2015 01:22 PM
Jigee
May 9, 2015 11:18 AM
thesushiboy
Apr 12, 2015 02:54 AM
0100010
Feb 1, 2002 10:26 PM
