Strange noise when DRL are on?
Old Jul 13, 2009
CivicMonkey's Avatar
CivicMonkey is an unknown quantity at this point
Hi guys,
My 2001 Civic LX-G sedan recently has been making a weird noise after i start it up. A weird noise which sounds like its coming from the CD player area, has been occurring every time my Daytime Running Lights are on. The noise goes away when I turn on my head lights, or shut off and restart my car a couple of times.
Any information on this problem would be greatly appreciated.
Thank you.
Old Jul 13, 2009
Re: Strange noise when DRL are on?
does it sound like buzzing? its prolly the daytime lights relay failing. or the module itself may need repair by taking it apart and resoldering the bad joints. its located where the hood release is i think, behind the plastic panel.
Old Jul 14, 2009
Thanks for the advice. gonna look into it after work.
Old Jul 14, 2009
Protan988's Avatar
Protan988 is an unknown quantity at this point
Hey, Ya my car does the same thing wondering what the hell the noise was. Glad that you asked. Now I know.
Old Jul 14, 2009
DDragon7's Avatar
Its either the DRL relay or the module. The module is located under the driver side dash, which is a gray box with a blue (I believe) connector. In the module you will see some bad solder points, you just have to resolder those points and it should work again...this is what I've read from previous stuff and has worked. I have yet to test this out. Another way to get rid of the noise is to pull the DRL fuses from the fuse box under the steering wheel, but you lose your DRL.
Old Mar 16, 2010
Protan988's Avatar
Could someone to a DIY for this? It apparently is a common problem on our cars
Old Mar 17, 2010
ExistEvolution's Avatar
ExistEvolution is on a distinguished road
gearbox i got the noise you described the other night, but i thought it was coming from my heater core, i'm going to listen for it again. could that be a reason why when i hit the gas my headlights brighten and dim (and no i have no heavy sound system or alarm installed, i do have lojack so no one come looking for my car lol)
i drive
Sep 14, 2015 01:56 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
JJ291
Sep 2, 2015 11:49 PM
WaryDriver
Aug 22, 2015 06:50 PM
mac25
Aug 21, 2015 11:14 PM
