Locking mechanism fails intermittently
Old Jul 8, 2009
armensd's Avatar
armensd is an unknown quantity at this point
Hello. I recently read a very helpful DYI here regarding removing the door panel. I'm fairly new to the DYI trade, but I'm very enthusiastic to take part of the DYI community.
On to the problem. While removing the front left door panel I must have broken something, because now my front left and back left door locks fail intermittently ( that is, once every 5 times or so one of them will fail ). Note I did not even touch the back door panel, though I bumped the lock switch while removing the front panel.
I'd appreciate if someone could give me some insight into how I could have broken this mechanism. I checked the rod connected to the door handle in the front, and it seems to be straight.
I would appreciate any suggestions.
Thanks in advance.
Old Jul 8, 2009
Re: Locking mechanism fails intermittently
i really have no idea how the other doors would be affected. the master lock switch is there, but either it works or it doesnt. maybe the connector is loose?
Old Jul 9, 2009
armensd's Avatar
Well, I checked the connectors and I don't see any problems there. Is it possible that my flipping the lock switch while the door panel was removed somehow bent the mechanical rods?
Any suggestions would be greatly appreciated. Also, if I could provide any further details that could help identify the problem, please let me know and I will do so.
Old Jul 9, 2009
each door has its own locking system tho. and those rods are very hard to bend. even if you did bend something, it would only affect the front driver door. i really dont think this problem was caused by what you did. maybe it was already there and you never noticed. it sounds more like a mechanical problem like the actuator going bad.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
DVexile
Jul 2, 2021 05:25 PM
maaronia
May 14, 2015 10:46 PM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
gabrown2
Apr 11, 2015 08:22 PM
