Post-accident lighting woes
Old May 20, 2009
madAd's Avatar
madAd is an unknown quantity at this point
I was recently in an accident to the left front corner of my '02 Civic. No full coverage, so going through the mechanicals myself. Anyways, the taillights and dashboard illumination lights stopped working. Headlights(even the smashed one) still work, brake and turns work. I cannot find where there is a taillight fuse or relay. Can someone tell me where these are, or if this might be a wire, although I don't see any wires that would've been affected( unless it's close to the headlight, washer pump or marker light wires). Thanks.
Old May 20, 2009
Re: Post-accident lighting woes
should be in underhood fuse box. im not sure what the fuse is so check em all. something prolly grounded out and blew the fuse.
Old May 21, 2009
CraigW's Avatar
"Small Lights" in under hood box.
Old May 21, 2009
madAd's Avatar
Thanx guys for the help,that was the right fuse. I did find the bundle of ground wires was damaged, so I spliced them and soldered them yesterday.
MyCivic
Electrical
Oct 28, 2021 11:06 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
Blazz
May 25, 2015 10:56 PM
werdnahall
May 17, 2015 11:37 AM
davidarenberg
May 16, 2015 08:45 AM
