IDLE problems!!
Old May 2, 2009
hiltzanthony's Avatar
hiltzanthony is an unknown quantity at this point
IDLE problems!!
I was wondering if anyone could help me! im having a problem when the car first stops and also if i put it into neutral. the RPM's seem to jump up and down till i put it back into drive.
It is a 1993 honda civic lx coupe!
thank you
Old May 2, 2009
Re: IDLE problems!!
rpm jumping around usually results from bad tps (throttle position sensor) on the throttle body. usually the whole throttle body needs to be replaced.
Old May 22, 2009
EM2withK20a2's Avatar
EM2withK20a2 is an unknown quantity at this point
Re: IDLE problems!!
no it may not be the throttle body last summer my brother was looking to buy an accord but it have that problem my dad found a wire in the trunk under the spare tire and it was grounding on the frame he removed it and the idleing problem stopped. he put the wire back and the rpms kept jumping again and to try and lower the price. my brother didnt buy that car cause the next day he found a nicce 1997 prelude for the same price that was a no brainer. hope this helps
Old May 22, 2009
baron340's Avatar
baron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of lightbaron340 is a glorious beacon of light
Re: IDLE problems!!
Could also be a vac leak.
Old May 24, 2009
mr22508's Avatar
Pistol grip pump in my lap at all times
mr22508 is a jewel in the roughmr22508 is a jewel in the roughmr22508 is a jewel in the rough
Re: IDLE problems!!
Sounds like a vac leak to me. But if you have messed with your idle air control screw it can jump until you reset your ecu. Or if you have put in a new aftermarket intake.
Old May 24, 2009
silver25civic's Avatar
silver25civic is an unknown quantity at this point
Re: IDLE problems!!
does it rev up then drop then rev? if so it is the sensor on the trottle body. my cousin had a h22 in his 95 civic and my friend had a prelude that did it too. unplug the sensor while the car is running if it runs normal then you need to change the sensor.hit me back and let me know if you fixed it.
manuel
Old May 25, 2009
big2000dave's Avatar
big2000dave is an unknown quantity at this point
Re: IDLE problems!!
Worst case ....it could be a blown plenum gasket....but this would only happen if you recently overheated your engine...then you most likely have more issues to go along with that.
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
crowtoo
May 11, 2015 06:50 PM
jakeconnor
May 5, 2015 07:30 AM
vtechcivic
Apr 21, 2015 06:58 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
