Engine Whine
Old Feb 20, 2009
Mike799's Avatar
Mike799 is an unknown quantity at this point
Engine Whine
How can I deterime which belt driven componet is bad. I have herd a whinning noise for a while which has just turned into a rumble. I think that it is an alternater, PS pump, A/C comperssor or the water pump. It is a 2001 civic with 110K. I checked under the hood and don't see anything loose. Any help would be greatly appreciated!
Old Feb 25, 2009
silvercivic1's Avatar
silvercivic1 is an unknown quantity at this point
Re: Engine Whine
it might be your transmission if it is a automatic it was the same noise i had then it went out
Old Feb 27, 2009
civic-king's Avatar
civic-king is an unknown quantity at this point
Re: Engine Whine
probibly powersteering. you can use a stehiscope or a screwdriver and hold it tight against the component you are testing. place your ear at the end or in the ear bungs. you can hear the noise. or, you can remove P/S belt. if noise is still present, remove A/C belt. if noise is still there, remove altornator belt. of noise is sill there, you need to look elsewhere....
Old Feb 28, 2009
Mike799's Avatar
Re: Engine Whine
I did just that and found that the alternater was the bad part. Thanks for the help!
moorebl
Aug 29, 2015 08:39 PM
pheaton
Bolt-on Engine Performance
Jan 9, 2002 08:43 AM
Cross
Jan 6, 2002 01:31 AM
pazzmore
Dec 24, 2001 07:39 PM
supercivic01
South
Nov 30, 2001 11:27 AM
