Hazard light not working!!!!! need help please!!!
Old Dec 11, 2008
hockey4ever's Avatar
hockey4ever is an unknown quantity at this point
I have an Honda civic EX 2002 and the hazard light aren't working. When i press the hazard light switch, i heard a buzzing noice that come from under the dash around the fuse boxe.... and the hazard light aren't blinking. I replaced the relay that control the hazard light and still have the problem. Any idea?? Thanks for you help!!!!!:
Old Dec 11, 2008
CraigW's Avatar
Re: Hazard light not working!!!!! need help please!!!
Turn signals working o.k. ??
Any turn signal bulbs burned out ??
Old Dec 12, 2008
Turn signal working ok ...... No bulb burned out????
Old Dec 12, 2008
CraigW's Avatar
I would check the connector on the hazard switch, Inspect and re-seat it a couple of times. Turn the hazard switch on and off several times move the connector around while listening and watching for changes in the symptoms.
Old Dec 12, 2008
How do we remove the hazard switch?
Old Dec 12, 2008
CraigW's Avatar
You will have to pull the center audio/HVAC pod out. Search under stereo installations for threads. You may be able to pull it slightly out and access the switch/connector.
Old Dec 12, 2008
DDragon7's Avatar
I dont think its the connection, if its unplugged, the turn signals should not work.
Old Dec 13, 2008
CraigW's Avatar
^^^^Yea, just thinking maybe a single connection had failed (you never know)
I guess there is more than one fuse, make sure to check those smaller ones in both fuse boxes.
The wiring info is attached.
Old Dec 17, 2008
Thanks for your help...... i'll try to figure it out with the wiring diagram!!!!!
ORskier
May 3, 2015 12:54 PM
tylerginevan
Apr 27, 2015 12:29 PM
Fastfebur
Apr 22, 2015 01:37 PM
civic_gt
Apr 19, 2015 08:15 AM
dooner24
Apr 14, 2015 07:51 PM
