Lower control arm replacement
Old Nov 24, 2008
cheeser's Avatar
cheeser is an unknown quantity at this point
So I was just quoted $700 to replace both lower control arms on a 2001 Honda Civic EX. A mechanic inspected the vehicle and said that the LCA's were cracked. I did not see this damage but I suspect it was from the fender bender recently that damaged the motor mounts as well.
A little background. I got help from this forum which I totally appreciated concerning the motor mounts. Well, after my wife rear-ended someone, the motor mounts were damaged and replaced. The vehicle, since then, has had a shaking/wobbling that occurs at all speeds. Fast forward to today...mechanic inspects the car and says that the LCA's are cracked.
So, is this too high a price to pay? Can I get the parts and have my mechanic do it for cheaper? I'm suspecting that this is the case, but I figured I'd ask you all who have experienced this. Thanks!
Old Nov 24, 2008
TRIZ's Avatar
Re: Lower control arm replacement
For rear contol arms- correct? If so...
You can pick up some blinging aftermarket ones for around 200, which include polyurethan bushings- much better than the rubber OEM bushings.
SPC makes some, Omni Power makes some, Megan makes some, D2 makes some.... just look around for one that looks good (since your not concerned about their different weights, mere grams)
Old Nov 24, 2008
mugenman's Avatar
"mmmBAHHHH" - vtec y0
i think hes talking about the fronts?? and 700 seems a tad high. shame you arnt closer. id do it for 150 lol
Old Nov 24, 2008
im pretty sure spc doesnt come with poly bushings. seems like rubber cause mine is starting to tear after a couple years.
Old Nov 30, 2008
cheeser's Avatar
Thanks for the replies. I found the front lower control arms for $110 each. I should be able to get my mechanic to do it fairly in-expensively. $700 seemed way to high as well.
Old Nov 30, 2008
CiViCPrAnInG2k1's Avatar
i just changed my LCA and it cost me 400 bucks.
now i need my ball joints fixed.
Old Nov 30, 2008
TRIZ's Avatar
Got pics of the crash?
Old Jun 23, 2011
EM2 Rookie's Avatar
EM2 Rookie is an unknown quantity at this point
is there a link for rear LCA removal?
Old Jun 25, 2011
TRIZ's Avatar
I dont think so, because I was going to make a DIY when I did it, but it was so simple that I forgot.
Its three nuts to get the center section off where you need the special SPC part to remove them (or the honda one) and then another nut/bolt combo on the outter bolts. Word of advice, when re-installing, do the inner three first, and then the outter bolt otherwise it will be impossible to line up.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
GolNat
Sep 10, 2015 08:25 PM
Pudnite
May 9, 2015 07:51 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
