?? other reason for white smoke other then head gasket related problems??
Old Nov 18, 2008
djaysin04's Avatar
djaysin04 is an unknown quantity at this point
Exclamation ?? other reason for white smoke other then head gasket related problems??
hey everyone,
this is my third post... ive been having issues with my 04 turbocharge civic, it overheats everyday and continues to work fine, im getting alot of white smoke all of a sudden after getting an alignment for meineke. and all of a sudden smoke from the engine. im thinking maybe he sabotaged my engine cause he did an alignment!! but anyways, crack my engine open recently thinking i had to replace the head gasket and it was fine.. .so i dont know what else it could be... also im running very rich.. anyone have any thoughts? thanks
Old Nov 18, 2008
Re: ?? other reason for white smoke other then head gasket related problems??
is there coolant leak somewhere splashing on hot engine parts? maybe from a hose, radiator, overflow tank, etc.
Old Nov 20, 2008
djaysin04's Avatar
yeah there is coolant splash that does go on hot parts, that im familiar with that but its never the amount of smoke that has been coming out recently, what color does fresh synthetic oil burn?
Old Nov 20, 2008
Protan988's Avatar
Protan988 is an unknown quantity at this point
lol all oil will burn like white smoke. Either your burning extreme amounts of oil or you are burning coolant somewhere. We cant tell you where.
Old Nov 21, 2008
djaysin04's Avatar
cool, thanks, i took it to a shop and they put some dye in my engine, im pretty sure im leaking oil somewhere... =D
Old Nov 22, 2008
TRIZ's Avatar
I thought oil burned black?
Old Nov 23, 2008
Protan988's Avatar
Maybe it does but on most cars ive seen its usually excessive smoke and has a funky smell to it when its burning oil.
Old Nov 25, 2008
GreenFamily's Avatar
GreenFamily is an unknown quantity at this point
Triz is correct.
Oil burns dark with a blue tint, this applies to both dyno(convention) and synthetic oils.
If you are seeing a white smoke then you are most likely seeing vaporized coolant.
Smell the smoke; if it has a sweet smell then it's ethylene glycol(coolant) if it’s a burning smell then it's oil related (could also be transmission fluid).
You will also see a large quantity of white smoke with a strong grey tint when running very rich.
BTW:
If your turboed and have a ritch mixture I would one) check for leaky injectors and two) get your computer dyno-tuned asap.
Old Dec 1, 2008
BoomerXx21's Avatar
BoomerXx21 is an unknown quantity at this point
i had white smoke and my car was burning shitloads of oil. i run synthetic and it was definately white, and it was definately oil. i blew rings it was fun.
Old Dec 2, 2008
djaysin04's Avatar
THANKS EVERYONE!! well i found out i was burning coolant!! my reservoir tanks erupts coolant like a volcano. and i have to tie a string to my cap now so i dont have to keep buying caps for the reservoir tank. anyone know why a reservoir coolant tank would erupt everywhere and i just replaced my radiator cap recently too, so im sure its not the cap. and its a koyo radiator as well.... thanks again.. if you have any questions for a better diagnostic just ask and i'll answer as promptly as possible
thana
Jun 15, 2020 07:05 PM
crowtoo
May 11, 2015 06:50 PM
hokiedad4
May 3, 2015 10:06 PM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
deus-ex
Apr 13, 2015 12:29 PM
